Pular para o conteúdo
  • Início
  • Help
  • Replacement Engine Help
  • English (US) Português (BR) Español (América Latina)
  • Entrar
  • Entre em contato
    • Início
    • Help
  • Entrar
  • Entre em contato
É necessário estar registrado para interagir com a comunidade.
Todas as publicações Pessoas Emblemas
Marcadores (Ver tudo)
139-0603 shop tricks RP1 Toro apps
Sobre este fórum
Sobre este fórum
  2. Fórum
Rehlko/ Kohler Engine replacements
Inscrever
Seja notificado quando houver atividade nesta publicação
Esta pergunta foi sinalizada
356 Visualizações
This is a place to post repower projects and best practices when swapping engines from OEM to Service master spec.
Please do your research and don't make assumptions. These results are from "in-the-field" swaps and require technical knowledge to complete.
Cancelar
CH730-0104 on a cub cadet.
Replacement with a CH730-0169 as it has a matching crank shaft and air cleaner. Unfortunately its closure plate mounts are different so the PTO clutch holder will need to be modified or moved. It also requires reuse of the old flywheel PTO adapter onto the new engine. The wire harness is also different so use of the RP1 would help modify the wiring. This is a #6 difficulty for replacement by a tech.
The Kohler CH730-0169 is a commercial-grade, horizontal-shaft internal combustion engine that is part of the Kohler Command PRO series. It's specifically a V-Twin, air-cooled, 4-cycle gasoline engine primarily designed as a replacement engine, most notably for John Deere equipment.
Key Specifications
Attribute Specification
Engine Series Command PRO CH730
Engine Type 4-Cycle, Gasoline, V-Twin, OHV
Cooling Air-Cooled
Displacement 725 cc (44.0 cu. in.)
Horsepower (Gross) 23.5 HP (Some listings suggest a Max. Power of 25 HP)
Peak Torque 38.4 lb-ft to 39.9 lb-ft
Crankshaft Horizontal, 1-1/8"×2.79" (or 2-3/4")
Cylinder Liners Cast Iron
Lubrication Full pressure with a full-flow spin-on oil filter
Oil Capacity 2.0 U.S. quarts (1.9 liters)
Starting System 12V Electric Start
Charging System 15 Amp (Regulated)
Features Oil cooler, hydraulic valve lifters, heavy-duty air cleaner
Jason Davis
i like the details about the Charging system.
i feel that could be easily over looked, but is very important to proper operation of the unit.
Ch620-3076 superseded to PA-CH620-3090 NLA
This engine does not have a direct fit up.
The wiring can be adapted with the RP1 repower kit but to have the same stator output the old stator would need to be swapped and a larger charge wire added so the amperage back to the battery won't melt the smaller wire that is standard on this unit.
--RP1 + stator /Regulator/ charge wire swap--
CAUTION! Because of the technical complications this swap of the stator should not be done by anyone but a trained technician.
CH640-3126 is the recommended engine for this swap:
The Kohler CH640-3126 is a Kohler Command Pro horizontal engine with 20.5 Gross HP and 674cc displacement, featuring a 1-1/8" x 2.79" crankshaft for Simplicity/Sun Star equipment. It includes electric start with a 15-amp alternator, a 7/16"-20 tapped hole, a 1/4" keyway, and is designed for commercial-grade equipment. [1, 2, 3]
Key Specifications:
  • Brand: Kohler Command Pro Series
  • Engine Displacement: 674cc
  • Horsepower: 20.5 Gross HP
  • Engine Type: 4-Cycle, Overhead Valve (OHV)
  • Crankshaft Size: 1-1/8" diameter x 2.79" length
  • Crankshaft Tapping: 7/16"-20
  • Crankshaft Keyway: 1/4"
  • Starting System: Electric Start
  • Alternator Output: 15 Amps
  • Mounting: Horizontal [1, 2, 4]
Features & Applications:
  • Heavy-Duty Design: Features a cast iron cylinder bore and a two-year manufacturer's warranty.
  • Commercial Use: Well-suited for commercial-grade equipment, such as riding mowers, zero-turn mowers, and wood chippers.
  • Simplicity/Sun Star Replacement: This model is often a direct replacement for engines on Simplicity and Sun Star equipment. [1, 2, 3, 4, 5]
AI responses may include mistakes.
[1] https://www.ebay.com/itm/404568121042
[2] https://www.powerequipmentdirect.com/Kohler-Engines-PA-CH640-3126/p68914.html
[3] https://www.youtube.com/watch?v=6IfsGcyaCxY
[4] https://www.smallenginewarehouse.com/ch640-3126
[5] https://www.partstree.com/models/ch640-3126-kohler-command-pro-engine-made-for-simplicity-20-5hp-15-3kw
Cancelar
Está gostando da discussão? Não fique apenas lendo, participe!
Crie uma conta hoje mesmo para aproveitar os recursos exclusivos e interagir com nossa incrível comunidade!
Inscreva-se
English (US) | Português (BR) | Español (América Latina)
Distribuído por Odoo - Crie um site grátis
