With the following BCS kit 92299003 you can swap engines listed below. The Recommended engine is a CH395-3149 for pull start and CH395-3041 for electric. The CH395-3031 spec has the same 10 amp charging system as the original engine. Some wiring may be required for these. Call us for more info. 1.800.888.7181
Share and discuss the best content and new marketing ideas, build your professional profile and become a better marketer together.
129
Vistas
