Pular para o conteúdo
  • Início
  • Help
  • English (US) Português (BR) Español (América Latina)
  • Entrar
  • Entre em contato
    • Início
    • Help
  • Entrar
  • Entre em contato
É necessário estar registrado para interagir com a comunidade.
Todas as publicações Pessoas Emblemas
Marcadores (Ver tudo)
139-0603 shop tricks RP1 Toro apps
Sobre este fórum
Sobre este fórum
  2. Fórum
Repower Toro 139-0603 with Rehlko/Kohler 2P77F and 2P77HD
Inscrever
Seja notificado quando houver atividade nesta publicação
Esta pergunta foi sinalizada
Toro139-0603
184 Visualizações
Repower Toro 139-0603 with Rehlko/Kohler KT724-3002 is the Low Profile Air Cleaner (LPAC) 24HP or KT745-3103 is the Heavy Duty Air Cleaner (HDAC) 26HP upgrade. (note requirements below)
Based on the engine specifications for the Toro 139-0603 (2P77F) Twin Cylinder Engine, the corresponding crankshaft is part number 127-9255. This crankshaft features a 1-inch (approx. 25.4mm) diameter PTO (Power Take-Off) end, which is standard for many residential zero-turn mower engines.
Engine Model: 139-0603 (Toro 2P77F)
Diameter: 1" is typical for this 24.5HP engine)
PTO Length: Approximately 3-5 inches from engine seal
Use 130-0676 Muffler
Cancelar
proton mail
Use of the RP1 is recommended for configuring the wiring.
https://www.smallenginesuppliers.com/shop/html/images/small_engines/kohler/parts/rp-1.jpg
Medart Engine, Jason S Davis
One tip to keep in mind, you might need 4 of part number 25 086 672-S, 3/8-16 x 1" self taping bolts to mount the New Kohler (Rehlko) Engine down. Block will come with 4 blind, not tapped holes. these will zip right in without having to try and tap the block.
Toro Models:
74453TE
404621105 -
999999999
122cm TITAN HD 1500 Series Riding Mower
3434-279
Engine Assembly
139-0603  ENGINE-2P77F
74454TE
404621153 -
999999999
132cm TITAN HD 1500 Series Riding Mower
3434-280
Engine Assembly
74690
400000000 -
406709229
TimeCutter MX 4275T Riding Mower
3433-832
Engine and Muffler Assembly
74690
406709230 -
407699999
3437-951
74690
407700000 -
409329999
3441-916
74690
409330000 -
410999999
3445-134
74690
411000000 -
411699999
3445-134
74694
400000000 -
406709110
TimeCutter MX 5075T Riding Mower
3433-833
74694
406709111 -
407699999
3437-952
74694
407700000 -
409479999
3441-917
74694
409480000 -
410999999
3445-135
74694
411000000 -
411799999
3445-135
74726
402491338 -
404314199
TimeCutter SS 4225 Riding Mower
3425-435
74726
404314200 -
999999999
3425-435
74726TA
400000000 -
999999999
3425-435
74760
402221160 -
404314199
TimeCutter MX 4250 Riding Mower
3425-436
Engine Assembly
74760
404314200 -
999999999
3425-436
Engine Assembly
74760TA
400000000 -
999999999
3425-436
Engine Assembly
74768
402327412 -
404314199
TimeCutter MX 5075 Riding Mower
3425-438
Engine Assembly
74768
404314200 -
999999999
3425-438
Engine Assembly
74778
402366555 -
404314199
3425-438
Engine Assembly
74778
404314200 -
999999999
3425-438
Engine Assembly
74874
400000000 -
409239999
Titan X4850 Riding Mower
3433-683
74874
409240000 -
999999999
3444-882
74877
400000000 -
409233856
Titan X5450 Riding Mower
3433-684
74877
409233857 -
999999999
3444-883
74887
400000000 -
406999999
Titan XS4850 Riding Mower
3433-685
74887
407000000 -
409378060
3443-708
74887
409378061 -
411455765
3445-128
74887
411455766 -
999999999
3450-432
74889
400000000 -
406999999
Titan XS5450 Riding Mower
3433-686
74889
407000000 -
409239999
3443-709
74889
409240000 -
411455454
3444-884
74889
411455455 -
999999999
3450-433
75745
400000000 -
406709999
TimeCutter MX 4275 Riding Mower
3433-627
75745
406710000 -
406954065
3437-956
75745
406954066 -
407699999
3437-956
75745TA
400000000 -
407529999
3438-866
75745TA
407530000 -
409349999
3441-879
75745TA
409350000 -
410999999
3445-137
75745TA
411000000 -
411699999
3445-137
75745W
400000000 -
407199999
3439-349
75754
400000000 -
406807735
TimeCutter MX 5475 Riding Mower
3433-628
75754
406807736 -
407031671
3437-957
75754
407031672 -
407699999
3437-957
75754
407700000 -
409477923
3441-881
75754
409477924 -
410999999
3445-178
75754
411000000 -
412559494
3445-178
75755
400000000 -
406753519
3433-629
75755
406753520 -
406753789
3437-958
75755
406753790 -
407694439
3437-958
75755
407694440 -
409568781
3441-877
75755
409568782 -
410999999
3445-177
75755
411000000 -
412719999
3445-177
75755
412720000 -
414169999
3456-167
75755
414170000 -
999999999
3462-182
75755TA
400000000 -
407599999
3438-867
75755TA
407600000 -
409299999
3441-882
75755TA
409300000 -
410999999
3445-174
75755TA
411000000 -
411487597
3445-174
75755W
400000000 -
407199999
3439-351
75755W
407200000 -
412259805
3441-883
QZS708GEM50200
404314159 -
406294344
Quest
4504-169
Engine Assembly
QZS708GEM50200
406294345 -
408644345
Quest
4504-746
Engine Assembly
QZS708GEM54200
408644346 -
411294211
Quest
4505-465
QZS708GEM54200
411294212 -
413950473
Quest
4505-993
QZS708GEM54200
413950474 -
416150474
Quest
4506-582
Cancelar
Está gostando da discussão? Não fique apenas lendo, participe!
Crie uma conta hoje mesmo para aproveitar os recursos exclusivos e interagir com nossa incrível comunidade!
Inscreva-se
Publicações relacionadas Respostas Visualizações Atividade
Engine swap Wiring Assistance and the "RP1"
shop tricks 139-0603 RP1 engine swap wiring electrical
fev. 26
172
English (US) | Português (BR) | Español (América Latina)
Distribuído por Odoo - Crie um site grátis
