  • +1 636.231.3326
  • +1 636.231.3326
Share and discuss the best content and new marketing ideas, build your professional profile and become a better marketer together.
CUB SBD
CUB SBD
  1. Drive Train and Hydraulics
  2. Forum
Service Advisory Summary: Cub Cadet Premature Side Bevel Gear Wear (CC-1132 / CC-1133)
SBDCUB
1 Reply
Cub Cadet Service Advisories CC-1132 and CC-1133 address potential premature failure of differential side bevel gear part #168T20-31560 in Tuff Torq hydrostatic transmissions.
Key Details & Overview
  • Advisory Codes: CC-1132 (units < 2 years old) & CC-1133 (units > 2 years old)
  • Issue: Tuff Torq Corporation reported that differential side bevel gear (168T20-31560) does not meet specifications, causing potential excessive wear early in transmission life.
  • Action Policy: Fix-As-Fail — Any transmission issue resulting from this gear failure must be repaired/replaced at no cost to the customer, regardless of original warranty expiration.
  • Failed Part Number: TT-1A646031570
  • Flat Rate Labor Time: 2.0 Hours
Affected Equipment (Model Years 2021–2022)
  • XT1 Enduro Series:
    • LT42 / LT42 KH: 13A8A9CS056, 13AOA9CS010, 13AOA9CS056, 13AOA9CS210, 13AOA9TSA10, 13AKA9TSA10, 13AKA9TSB10
    • LT46 / LT46 KH: 13A6A9CT009, 13APA9CT056, 13APA9CT210, 13APA9TTA10, 13AQA9TTA10, 13AQA9TTB10
    • LT50 KH FAB: 13AQA1CL056, 13AQA1CL210, 13AQA1TLA10, 13AQA1TLB10
    • ST54 KH FAB: 13AQA2CM010, 13AQA2TMA10
  • XT2 Enduro Series:
    • LX42 KW FAB: 13AGA1TEA10, 13APA1TEA10
    • LX46 KW FAB: 13AFA1TNA10, 13AQA1TNA10
    • SLX50 KW/KH FAB: 13AFA2TLA10, 13A5A2TLA10
    • SLX54 KW/KH FAB: 13AFA2TMA10, 13A5A2TMA10
Affected Transmission Assemblies
  • 918-07207A: K46DM Hydro Trans Assembly
  • 918-07208A: K46DS Hydro Trans Assembly
  • 618P08373A: TL200D Hydro Trans Assembly
Claim Instructions
  1. Inspect the unit for symptoms outlined in CC-1132 / CC-1133.
  2. Verify model number and serial date range (2021–2022).
  3. If unit is within 2 years of purchase date, log warranty claim under CC-1132.
  4. If unit is past 2 years from purchase date, log warranty claim under CC-1133.
7 days ago Author Best Answer
Don't forget to follow the instructions in the Bulletins above.
Rule of thumb applies to check the 3 B's (Belt--Brake--Bypass)
See Jason Davis's note on this in the knowledgebase.
